abs,stabilitrak,traction control lighs on. wheel bearings & rear sensors replaced. what is next issue I should look at.Would a AL 619 scanner by Autel be helpful. thanks Rick Toledo
If the ABS light comes on for any reason, the stabiltrack and traction control lights will come on automatically.
That’s because the stabiltrack and traction control systems rely on the ABS system to function.
If that scanner can also read ABS codes, it might be helpful.
