2011 Toyota Avalon locks
Anyone else loose lock-control on passenger and rear doors. Driver door works from fob or inside door switch. All 4 will lock from fob or inside door switch. Passenger/rear doors will not unlock from either.
Looked for fuse- couldn’t identify which one from manual or on-line diagrams. (not an auto mechanic, but not foreign to backyard repairs.)
If the rear passenger door does not unlock, check if the child safety lock tab at the latch is set to the lock position.Also, insert key into driverside keyhole and turn the key 2 times conterclockwise,that should unlock all doors. Report back.
