I had my rear brakes done on a 2011 46,000 mile 4 runner limited along with tires rotated. After that I had vibration in my stearing & wabbling. I had the truck tire balanced & I still feel a slight vibration with a suttle bounce in the back of my truck. Please advise
The mechanics here may have better info, but if you have not done so already, re-torque the lugs on each tire. I had those symptoms once after a mechanic had the wheels off and found two tires with finger-tight lugs. Snugged em up, problem was solved.
