Does anyone know how to get the door panel off of a 2011 Jeep Compass without breaking anything? I’m scared to death to go prying on the thing because I can imagine everything inside falling out on the ground. I’m pretty sure I’ve removed all the little panels and bolts. The reason I’m doing this is because my power window won’t roll up and I’m guessing it’s the motor.
Hope this helps.
Wow. That REALLY detailed. Thanks! That helps a ton!
Before you jump on motor make sure to test the electrical connection/switch at the connector. Also try using 12v to move it up or down.
