Passenger window control switch quit working. (Door locks still work.) Driver side can control passenger window. Replaced switch - same problem. However when driver side control switch was disconnected, the passenger window switch worked. Reconnected driver side switch - then passenger switch stopped working. Replaced driver side switch and have same problem with passenger window switch. Any suggestions?
Likely wire has had the insulation worn through as it passes from the car into the door.
