2001 Dodge Dakota passenger windows not working
Im having an issue with my 01 Dakota. The passenger and rear drivers and passenger side windows do not work when my passengers try to control them, but they work from my driver’s door (no the lock is not on). Has anyone had this issue? I tried doing some research on it, but only found stuff about windows not working from any switch. Thank you
The power to all the other windows first passes thru the drivers door module.
The lock may not be on, but the switch inside is probably broken and not allowing power to the other windows.
Here’s the wiring diagram.
Also take a quick look at the wires that go from the driver’s door to the truck’s body, located in the door hinge area. See anything unusual happening there? Broken wires, insulation chaffing?
