my right turn signal didnt work so i installed a few new ones and still doesnt work
A few new ones… What new ones? Turn signal bulbs? Check for voltage and ground at the socket if a new bulb didn’t fix it.
Could be a problematic turn signal switch, the gadget you move on the steering column. Are the turn signal bulbs used for other functions, like the emergency blinkers? If so, you might be able to get a clue to the cause by experimenting if the turn signal bulb lights up then.
