2005 Chrysler Crossfire - Turn signal issues
My left turn signals stopped working. All bulbs, including flashers, are working. Rt. turn signals function fine. Fuses are ok. Help?
Very probably the turn signal switch itself. With your diagnostics so far you’ve pretty much eliminated everything else. One more diagnostic maneuver: What happens when you turn on the four way flashers?
They function normally.
Ok,my vote is even stronger for turn signal switch
Thank you, I suspect the switch as well. I appreciate your help.
