2011 Buick Regal - Brake light
Brake lights won’t come on unless I’m pressing the brake through the floor board. How much is this repair or is there a recall
Your brake light switch on the pedal support needs adjustment. It takes about a minute unless the lower panel needs to come out so 10 minutes. It is important to get this fixed.
Thank you Mustangman!
If the switch needs to be replaced, the part runs $16 and one-half hour labor. Problems with the brake light circuit can cause other weird symptoms, like w/the cruise control, etc, so good idea to get it repaired asap.
