Brake Lights
My brake lights (both sides) plus the brake light on my spoiler are not working. I am assuming they have not all blown at the same time so I checked the fuses. I pulled all fuses for lights and they did not look blown. Is this going to be an expensive problem to fix or something I can do myself? Any suggestions are appreciated.
Check for a misadjusted/defective brake light switch above the brake pedal.
Once you find the switch you ought to be able to replace it yourself.
If you have cruse control, turn it on in a safe area then gently press on the brake. If the cruse control kicks off, then it is the brake light switch.
Cruise control usually has its own brake pedal switch. They are mounted on a little bracket above the brake pedal arm…
