2010 Ford F250 - Fuse problem
73,000 miles, A/C clutch 10 amp mini fuse blows after a few minutes run time.
Ozark, AL
Possibilities:
  • Faulty A/C clutch solenoid
  • Faulty A/C clutch mechanism
  • Faulty wiring
  • Incorrect size or faulty fuse
  • Faulty Fuse block
With A/C problems it is always a good idea to ask your shop to check the engine compartment fans.
This same subject has come up in the forum a few times recently. You should be able to find those discussions using the forum search feature, link upper right this page.
