2007 Chrysler Pacifica- Won't accept fuel
Its almost impossible to fill the gas tank. The pump shuts off after maybe each quart if that much. We have spent over $800 on it at a local mechanic to only make it worse. Any help would be appreciated. Thanks.
Have they checked the Onboard Refueling Vapor Recovery system?
Because if this system is restricted, the fuel tank can’t vent when refueling the vehicle.
And this causes the gas pump nozzle to constantly shut off.
