2006 VW Passat won’t start
I was in the interior fuse box by the steering wheel and I put a fuse into the number 6 slot in hopes to fix my interior lights I also had the key in the ignition with the car on and when I went to remove the key it would not come out so natural I removed the fuse in hope to get the key remove it would not come out when I push the key in the car doesn’t start but my dashboard displays still works with some force I was able to get the key out. I was able to lock the doors remotely as well as unlock etc but when ever I put the key into the ignition it lockes the key again and the car doesn’t start… I have tried disconnecting the battery but it had no effect please
Sometimes,rocking the steering wheel a little left and right will unlock the key from the ignition.
