a noise in the rear strut sounds like out side but dealer says noise is inside of the strut
If the rear struts are bad it does not matter where the noise sounds like it coming from. And for a 2006 you can get struts at an independent shop cheaper than the dealer . Don’t replace just one rear strut , do both and you might need front as well.
And a wheel alignment as well.
