My 2006 Honda Odyssey has been leaking oil for months. My mechanic has replaced every seal, tightened everything up, and replaced the pcv valve too. Each time I get it back a new oil leak appears. It is the oil leak that will not end! I have put $1,000 into this. I would just give up if the oil leak weren’t so bad. It’s really bad, and three mechanics don’t know why my van keeps generating new leaks. I hope someone here has a hint!
none can see if leak is on top of motor or down low?
new valve cover gaskets?
camshaft seals?
front timing balancer seal?
oil pan gasket?
oil filter adapter and/or oil pressure sender does not leak?
last but not least. rear main seal. did he remove the transmission? you would certainly have paid for that?
i say take it to honda dealer and say nothing but have them find leak
