Battery is charged but the are no ignition lights when the key is turned
Does anything electrical work? LIke the headlights, radio, etc? If the problem is everything else works, just the normal dashboard warning lights (check engine, brake, etc) don’t turn on with the key in “on” like they used to, my guess is an ignition switch problem. Is it still possible to start the engine and drive the car normally?
