Why does the engine not start at times when the ignition key is turned? Nothing turns on, but on the second or third try it will turn on and start.
Some more information would be helpful. Is it a standard or automatic? Do dash lights (and other electrical accessories) appear to work normally with the key on? Does everything “go dead” when you turn the key to start position?
