2006 BMW 750 - Can I change the type of shocks?
Can you switch out the air ride rear shocks for regular shocks or gas shocks? vin# WBAHN83536DT59352
I really don’t see why you couldn’t.
BMW engineers designed & tested car’s suspension system so the handles safely; if design is changed by replacing a part with something other than original, car may never have been tested it in that configuration, so could be unsafe. May be ok, but suggest for safety-sake to check with BMW specialist first.
Replacing the air ride shocks with standard shocks has been done many times , all it takes is a competent shop .
That BMW is at an auction, current bid is $2500.
While you can probably do it, I couldn’t find a conversion for that particular model. You might try asking on a couple of the BMW forums. The coil over kits I found specifically exclude cars with the active ride system.
https://www.suncoreindustries.com/product/17603/rear-self-leveling-air-to-coil-spring-strut-conversion-kit-bmw-7-series-e65-e66
Good looking car imo. BMW designers do a good job on car styling.
