My car has 245x70xR16 Petlas Explore PT411 tires. What should be the minimum and maximum tire pressure
There should be a sticker on the inside of one of your front doors with the proper pressure - assume that to be the minimum. It is also in your owners manual. The maximum pressure is molded onto the sidewall of the tire. Do NOT exceed that pressure while the tire is cold.
Thank you so much for the information
