2005 Dodge 5.7 Hemi magnum, after every fueling engine will quit several time within 1/4 mile and then upon restrting each time will continue to run until next fueling. No engine check light. Dealers no clue.
Iam curious: Are you filling to max,trying to put every last bit in? Does stooping a little short of totally full change the situation?
A saturated canister would set a CEL.
No, pull nossle after handle clicks off; and it does not matter how much fuel you put in, just a couple of gallons to fill.
