Need some help… Just got an oil change in South Dakota… 3200 miles from home or so… the guys at the lube n go said that there is a red fluid leaking from what they called the final drive. They didn’t seem very knowledgeable about what was happening. Transmission fluid and power steering fluid are full. Could this be the front differential fluid? If so, how do I check it? AND how serious is it/what sort of repair bill am I looking at?
Sitting at an internet cafe posting this hoping I can get an answer quick! If you’re out there you’re help will be greatly appreciated!
This may be a relatively common problem with CRVs. My GF and I test drove a 2003. I looked under it like I always do when test driving anything, and saw a transmission fluid leak in exactly the same spot you describe.
