2004 Dodge Ram 2500 - AC issues
AC not blowing cold air looking for recommendations to replace
Looking for recommendations to replace what?? The vehicle?
You could have an inexpensive part or require a major overhaul of the AC system, it could just be low on freon from a leaking O-ring, you could have many many different things wrong, just need to have it checked out to know what it will need…
Best to take it to a pro mechanic with the proper tools and experience to properly diagnose the issue…
?? Are you asking for ideas what part in your AC system needs to be replaced? Suggest before replacing any parts to get a pro-diagnosis so you know for sure what’s wrong. there are many reasons that can cause this symptom. It is very easy to run out of money replacing parts on a guess before you finally replace the correct part.
Two common reasons for no cold air
  • A/C compressor’s clutch isn’t working. A shop tech can quickly tell if that’s problem.
  • A/C condenser cooling fan isn’t spinning. That fan is in the engine compartment. Since AC cools by moving heat from the passenger compart to the condenser in the engine compartment, if the condenser fan doesn’t spin the condenser gets too hot for the AC system to work correctly.
