I have an 04 MDX it has over 100k on it, and about the time it was approaching that milestone, the transmission started “hesitating” when shifting into overdrive… then it began to try to shift into overdrive way to early driving in town… and it felt like we were riding across rumble strips every time it would do this…
We have found out… that if we do not move the transmission selector lever into the overdrive position, but leave it in D4 [thus manually avoiding the overdrive] it does just fine… we just suffer in the gas mileage dept., but it does not feel like the transmission is going to fall out while riding in town…
My question is; is there a way to disconnect or disable the overdrive so that no matter what gear someone puts it in, it will not try to shift into overdrive by itself.
When I am driving it; it is not an issue, I remember to not use overdrive every time; but when the wife or the children drive, they sometimes forget, and I am afraid it is going to do real damage beyond low gas mileage…
I have heard that this is a common problem with this vehicle, and that replacing the transmission is a very short-lived solution, as the problem is design related and will eventually happen again.
suggestions?
