The passenger side window on my tundra opens and closes when using the drivers side switch. When using the passenger side switch it will not work. However, if I use the drivers side switch to open the window, then the passenger side will work. I’ve replaced the passenger side switch but it doen not help. Any ideas???
Then you may have a broken wire inside the passengers side door.
