Hello all,
I have a 2003 Santa Fe with 108k miles on it that seems to have an attitude problem. I was driving home from a Christmas get together on the highway, when my engine stalled, hiccuped, stopped and the check engine light came on. When I tried restarting the car, the engine wouldn’t fire. The battery was fine, and I had a half tank of gas. After about 15 minutes of sitting, I was able to get the car started and driving again. After about a day and a half and a refueling, the check engine light went out and the car behaved as normal until this evening.
I went to the gas station, put $15 in the tank (brought the tank up to about half), and as I was stopped waiting to pull onto the road, the engine died. No hiccuping, rough running or anything, it just plain stalled and shut off. Again, after ~15 min, it started. I turned back up the road to head home (Was going to head about 30 miles west to see a friend but decided against it), after I stopped at a stop light, it stalled out again same thing. Waited ~15 min, it started back up with the check engine light back on. (But wait there’s more!) Another stoplight, another stall. This time however, it would not start at all after 30 plus minutes. By this point, my battery was pretty run down, so I managed to get a friend to give me a tow.
Thankfully, I have to bring it it for servicing tomorrow anyway for a completely unrelated issue, and just towed it over to the dealer.
Any clue what gives or what I should make sure the dealer does?
The internet seems to want to point me towards a bad ignition coil or a bad crankshaft sensor, but my mechanically inclined friends are leaning towards an electrical issue or a problem with the fuel filter/pump/line.
Thanks for your help!
EDIT: The check engine code is P0335
