drivers window will not work I replaced the switch but still not working.now I guess it`s the motor but I read there could be a jamb in the track which will keep it from moving? maybe??? what do I do next??? tom
Remove the door panel to access the motor and window mechanism. Find what’s not working, or jammed up. You should be able to hear the motor try to raise the window, even if it is jammed. If not motor sounds, or evidence of electrical stress when trying to operate the window, then the problem is at the motor.
You did check the fuse, right?
the passenger side works so are there seperate fuses? I`ll check…tom
fuse is fine.now to open up the door panel to check for broken wires…tom
