2003 Jeep Grand Cherokee - White smoke
White smoke sometimes appears from the exhaust on my 2003 Jeep Grand Cherokee, V8. What is the problem?
Maybe blown head gasket. If that is the case, it will not get better, it will get worse and smoke nearly all the time. If the cylinders fill up with coolant, the engine will be destroyed. You might want to get it professionally tested.
