Hi all,
I recently came to notice that 3 of my 4 brake lights were permanently stuck on with the inner passenger’s side light working normally. I removed the panel under the driver seat and found that a piece attached to the pedal arm that pushes in the brake light switch had broken. I replaced the broken piece and now all the brake lights except for the inner passenger’s side light function normally, which no longer works at all when pushing the brake pedal*. Any ideas?
EDIT: some additional info: When using the key fob to lock/unlock the doors, all the lights function normally.
Thank you in advance!
