I can’t get my car into gear and, yes, I am pushing on the break. Any ideas as to what might be wrong?
Pressing on the “break” wont help. Are the brake lights also not working?
Pressing as hard as you can on the BRAKE might.
If it shifts the brake light
switch needs to be adjusted or replaced.
Still wont shift?
Check the brake light fuse & the brake light switch.
The fuse list in your owners manual will tell you which fuse to check.
