My low beams work just fine but my high beams wont turn on. I turn on my lights all the way so they should be on but even on the dashboard it is saying that the headlights aren’t on. Checked the fuses and they were fine.
Fuse 38? A 20 amp fuse? Are you sure the high beam bulbs actually work? Are the headlight connectors corroded or burnt? f all that checks out, suspect either the headlight switch itself or the high-beam switch.
