The 3 power outlet combo on the dash has stopped working - appears to be blown fuse. I have tested those on the diagram - all are good. Where the &*%! is this fuse?
You have 3 fuse boxes. 1 under hood, 1 on the side of the dash when you open the door and 1 on the left side of steering wheel.
check fuses that say AUX power and ones that say CIGAR or SEO.
ᐅ Chevrolet Tahoe (2002) Fuse Box Diagram
(fuses.guru)
If they are good, then check behind the 3-power outlet for a loose or bad connection or burnt wire.
Good link. Wow, I can see why OP can’t find the fuse they are looking for, vehicle has a whole lotta fuses. My truck only has 5 fuses … lol …
