2001 Tacoma Sispension Problem
18 months ago due to excessive vibration (i.e. the front of the truck nearly shaking off) I replaced the tie rod ends and the upper and lower ball joints.
Apparently that only addressed the symptoms of an underlying problem and the vibration is back.
I have purchased the new ball joints and tie rod ends again and I plan on replacing the struts as well because I have 150000+ miles on the originals.
I am at a loss to discover the root of the problem and my research so far has only discovered that there are several types of wheel balancing out there.
I bought new tires about 6 months ago. p265r16, oversized but still fitting on the original rims.
Toyota recommend something called a load force balancing. Will this solve my problem?
