Drivers side carpet is wet. I have blown air through the drain hole from the engine compartment. While the car is idling, what is coming out the drain with the AC running. My question is, should there be some kind of right angle hose attached where the drain tube enters the engine bay directing waste water to the ground? If there is, I can’t find a part number to save my life.
It should have read “water is coming of of the drain” not “what is coming out” Sorry for the confusion…
