2003 Mitsubishi Galant
When I run the air conditioner water runs into the front passenger floorboard instead of outside. What is causing this?
[b]The condensate drain tube under the passenger side of the vehicle is plugged up.
If you look under the vehicle, passenger side, you’ll find a rubber tube pointing down to the ground. Blow compressed air into the tube, or take a length trimmer string and poke it up the tube to dislodge any restriction.
Tester[/b]
This is my sons car and I remember my husband and son looking for the tube and not seeing it…it is hidden on the galant?
Sometimes they can be difficult to see, or they are missing. There is a drain tube there somewhere, or at least there should be one.
