2001 Ford Power Steering Pump
I replaced the power steering pump on my U code engine and am having difficulty knowing the configuration of the high pressure seal(s) at the pump. I would be interested in knowing the exact part number and the specific location of the teflon seal, and if there is a second rubber 0-ring at the tip. Any input is appreciated - - thanks
Personally, I would just get a kit that has an assortment of different size Teflon seals
Those Teflon seals technically also need to be “sized” with a tool, afaik . . . which isn’t hard to do, imo
Is this a 3-liter ohv V-6 Vulcan, commonly found in Ford Taurus?
Yes, common 3.0 “U” code. I have stretched a few of those seals, which is not difficult but have not been able to seal it properly. I’m not sure which seal in the kit is designed specificly for this vehicle. I appreciate your input.
here’s one sizing tool kit, just to give you an idea what they might look like
Those are seal installation tools. But, the proper size socket also works.
Much appreciated - - looking forward to moving this vehicle out of the garage today - - Thanks
