I have a 2000 Toyota 4runner. I have a problem with a rear wheel sticking as in the pads seems to be sticking to the drum. I have dismantled and reassembled all the brakes but the problem persists. If I stop the car then let off the brakes the car hesitates until the brake shoe lets go of the drum, in some cases it’s a loud clunk. If I do the same w/ the emergency brake (to rule out the wheel cylinder) the same thing happens. Is this caused by unevenly worn brake shoes? When I took the brakes apart the previous mechanic had put them together wrong and the spring holding the shoes at the top of the assembly was binding on the adjuster.
Related topics
| Uneven braking, what to try next | 2 | 550 | December 20, 2008 | |
| Right Rear Wheel doesn't roll - Toyota 4Runner 2000 | 3 | 736 | March 19, 2011 | |
| Breaking | 13 | 1178 | August 12, 2009 | |
| Right rear wheel rubbing/sticking | 1 | 791 | June 27, 2009 | |
| 2005 Toyota 4Runner - Downhill shaking | 5 | 1016 | June 10, 2021 |
