scaned reads no connection
What is the.exact code, in the form Pxxxx?
Do you mean your scanner is indicating no connection?
does the vehicle have power? Is the key on?
What is the reason you are trying to hook up the scanner?
Try turning the ignition switch Off-On, Off-On, Off-On.
The odometer should show the code(s).
