Greetings from Kansas City. I have a 1998 Chrysler Concorde with 67,600K. The engine is starting to stall shortly after driving a few miles with no warning other than the engine light coming on. I can put the car in neutral and it will start right up and run just fine. The engine temperature is fine. Any suggestions or additional questions will be greatly appreciated.
Thor first clean both ends of your battery cable connections, especially the ground side. If that doesn’t stop it , pull off the large rubber or plastic tube between the air cleaner and the throttle plenum and clean the inside of the plenum it with throttle body or carb cleaner.
I
