i have a 1996 honda civic lx. my power window behind my driver seat will only go down and not up. but if i open the door up, i can make the window go up. only the down button will work on the switch will work. how can i fix it where my window will go up and down?
I suspect you have a broken wire between the door and the door post. You’ll have to check for continuity to the switch.
Activate the switch when testing and have the key ON.
fix the wires in the door jamb
know issue with Hondas
good luck
