The power windows for both rear windows won’t work. Check the fuse and couldn’t find any problem. Any discussions?
Thanks Russ
Does this car have a switch that disables the rear power windows? Is it switched off? Switch it on. Still won’t work, start with that switch.
Switch OK? Then the wires leading from that witch thru the door jamb have likely broken from opening and closing the door. Trace the wire and find the break. Start with where they bend. Good Luck!
