1995 Ford Aerostar Driver Window
Greetings
I am looking for wiring diagram for 1995 Aerostar, drivers door. The left window switch has no power. Thank You in advance
A lot of these problems are due to broken wires in the door jamb where they get flexed a lot. Ebay is a good source for service manuals. You should be able to go to your local library and get some info also.
