1994 Jeep Grand Cherokee alarm system
Seems to still go off for some reason when I unlock the door normally.
The key will not stop the alarm as before.
I have to pull the fuse to stop it.
any ideas ???
Check the switch connection to the alarm that is tied to the key lock and make sure it is working ok. If that is good then it would appear that something in the alarm system has failed.
