Where do I find the a/c drain and how do I unplug it so it will drain outside the truck instead of on my passengers feet?
Does no-one know?
Look under the vehicle passenger side firewall and you’ll see a rubber tube pointing at the ground. You can clean the tube out with compressed air or use a length of string trimmer line .
