1992 Ford Thunderbird pulls left when braking
Car pulls left when braking. Replaced all front end parts including struts.
The brakes on that side are taking hold more than on the other. If you had the brakes done recently take it back to the shop that did the work. If not, have the brakes looked at.
Remember, it is just as likely to be caused by the right side brake not working as it is the left side grabbing. The back brakes can cause this too.
Does “all front end parts” include ball joints? If not, that is a possibility.
Since all front end parts including struts were replaced has the car been on the alignment rack? If not, it should have been.
The car is 28 years old and that brings up the possibility of original calipers and whether or not the right side caliper piston is sticking or the caliper is sticking on the sliders.
Thank you all. Yes, the car has been aligned by two different shops. I replaced the calipers because of this issue and it didn’t change. Rear brakes are OK. I also replaced the front hoses and the master cylinder. Ball joints are tight. I suspect the strut bushings but the “rubber” is new. I had an older mechanic who worked on these cars look at them. He suggested an alignment. How many alignments do I need? :slight_smile:
One more should do it. :wink: Seriously, I’m not a mechanic but it doesn’t sound like another alignment will solve your problem unless the guys who did the last two are utterly incompetent. Unless some part is damaged I’d go back to a problem with the brakes. As @oldtimer-11 said, the left brake or even the front brakes aren’t necessarily the source of the trouble.
If you can do it safely, try braking with the parking brake while underway. That puts only the rear brakes - or one of them - in play.
The rear parking brake is cable actuated so if the rear brake is having a problem with a sticking caliper or hose, it won’t show up using the parking brake.
I pinched off the hoses for the front brakes so that only the rear brakes were active. They worked fine. No pulling.
Great detective work. You’ve isolated the problem to the front of the car and my money’s still on the brakes.
The problem started as pulling left when hitting the brakes. The first thing I did was the front calipers and rotors. There was no change. So I’m up against the odds of getting a new caliper failing the exact same way on the same side. Maybe I’ll swap the calipers and see if the problem follows to the right side.
Problem solved. I figured I should close this loop. It was a bad ball joint. Car tracks nice and straight now. I had brought it to 3 shops and all said that the ball joints were fine. It recently developed a “squeak/groan” when turning. I thought ball joint so replaced all 4. That was it!
Thank you all for your help.
We appreciate it, many people never bother to come back and let us know what the resolution was. Glad you figured it out, happy motoring :slight_smile:
