it is a buetiful car with only 90,000 k miles. my only problem is that the gas pedal seems to stick.
Have you tried apraying lubricant on the linkages, both at the pedal and under the hood?
The throttle plate might be sticking. You don’t want the throttle to sick full open do you? You need a mechanic to check it out.
