I have an 1985 911 and want to jack it up to change the brake pads. Does anyone know where the jack points are becasue I cant find them?
The pinch weld under the rocker panel is an acceptable jack point. Don’t forget to use jackstands!
Rather than using the factory jack points use a floor jack and position it to lift on the torsion housing.
