Have a '79 Fleetwood Southwind on a '79 Dodge M400 Chasis and lost ignition key what are my options? and whats the best remedy? $ is an issue time is not
PS Have contacted Dealer and VIN key replacement a no go
A mobile lockshith will come to you and make you a key, usually for less than $100…
If the switch is in the dash, you can remove and replace the entire stitch yourself with a universal ignition switch…But if it’s in the column, the locksmith is the best option.
If you just don’t care, you can force the lock with a hammer and square shank screwdriver…
