I bought a focus back in 2013 its been vibrating since i bought it. Didnt think it was an issue. In 2014 i had the cars ecm reprogrammed and the safety switch replaced. That april i had the spark plugs amd wirrs replaced. In the fall of 2014 i had the torque strut mount and transmission mount replaced to fix the vibration, didnt work. Ive had several mechanics take a look
Mechanic A: its internal issues
M-B: its the main motor mount
M-C: the a/c is over charged
M-D: the belt tenchener needs to be replaced
I haven’t tried fixing any of those response cause i dont have the money to investigate (all mechanics didnt charge me to look at the car)
Yes i actually watched the arpms and when it get close to 1000 the vibration sounds smoother but gets to 700 sound more spread out ( this is just sitting in the car not moving) i would attach a video but my phone wont let me
When we are driving you can here the vibration coming from the engine with thw stearing wheel shacking, and the driver seat becomes a vibrator seat, as we slow down you can feel it in the passanger seat.
Does the vibration change as you slowly ease off or ease on the gas (i.e., go from decelerating to accelerating)? Try it a few times. This could be a big clue. You might have both an engine and a driveline vibration.
Insightful asked: “Have you rotated your tires recently?”
The OP replied: “I believe they were when we got the new tires”
@adondria42
That response actually makes no sense.
Tires are typically rotated every 5k miles, or every 7.5k miles, or–at the most–every 10k miles.
How would one “rotate” tires that are being installed for the first time?
