Trying to figure what I need and how much it would cost to fix this theres a bolt sticking out through the strut mount I think the shock is seized or something but every little bump the bolt hits up underneath the wiper right now we have that vehicle parked just trying to price it out
Which bolt is sticking out of the strut mount?
The one in the middle ya that’s why I’m concerned it hits the metal above it to
What’s probably happened is, the valving inside the strut has failed and strut rod can no longer move up and down. This then causes the upper strut bearing to be pounded out from the shock from the front suspension takes
This will make the vehicle ride like a buckboard.
Your vehicle is a candidate for a pair of Quick-Stuts
http://www.monroe.com/en-US/e-catalog
Thanks should I have both changed out?
You always replace struts in pairs.
