i checked with nissan dealer and they informed me that this vehicle use Nissan J Fluid.  It is $11 per quart.  then, i checked with local pepboys.   they showed me castrol international and the description told me that it is good for Nissan J fluid as well as M fluid as well as anohter dozen of import cars (honda, etc).  the cost is only $4 per quart.  Is it save to use Castrol International ?
 tx
The answer is in your owner’s manual. Follow whatever it says in the owner’s manual.
Castrol Multivehicle Import Fluid says it meets Nissan J-Matic fluid standard. Problem with owner’s manual is that it quotes the manufacturer’s fluid name, and sometimes a standard that must be met. That makes it harder to determine if an aftermarket fluid is correct for the car (by marketing and manual layout design, I suspect). Bottom line is that Castrol says the fluid I mention meets the Nissan J standard.
I could not find “Castrol International” on the US Castrol website, but believe you mean the Multivehicle Import fluid. Make sure you get the right stuff.
Thanks much.
